3 Attachment(s)
		just replaced my shaft packing
		I just replaced the shaft packing in my '05 Mobius LSV.  It was fairly easy.  It took about 1.5 hours, and I'm kind of slow.  I made a little tool out of a piece of coat hanger to use for removing the old fiber that worked really well.  I've attached a picture of it and a closeup of the tip.  The large bends are just a way to hold it.  I bent the tip 90 degrees and then ground it down to a point to be able to grab the old fiber.  I also attached a picture of the wrench I used.  It's a plumbing wrench I got at Home Depot.
I was a little surprised when I removed a total of 5 pieces of fiber (none of which were broken).  The instructions I used said to install 2, maybe 3 pieces.
I replaced it with 3 pieces of GOR fiber.  When I hand tightened it at the end of the instructions, it went all the way up against the lock nut.  Does that mean I need to add another piece of fiber?  Maybe that's why there were 5 in there previously?
I haven't put it in the water yet to see if it is leaking.
