Originally Posted by
mcdye
Awesome work.
I was reviewing my notes that I made when I brought my boat. The dealer and I did the water drain since I brought the boat in the winter and we did a sea run. The only additional item that I had in my notes was to drain what he called the "J" hose. You can see it in the second picture up. It is between the thermostat housing and the lower part of the engine water pump(not fresh water pump). We disconnected from the pump end and drained.
Another item, How many of you spray the engine with some sort of rust inhibitor once all done? (wd-40, engine stor,etc..)
