I'm at my desk instead of on the water on the 4th of July, so of course I'm killing some time online... I got a few PMs (that's finally replied to) asking about the hose extensions with the Enzos on a G6 boat. figured that info might help someone some day...
I've only got a picture of the hose before extending it. The hose that's shown looped around tightly can be extended and use the 3rd port on the bag that is shown in this picture with an air bleeder plug. Swap the plug fitting and the flow rite fitting and extend the hose for a cleaner install. That tight bend actually kinked on the other bag, and was so tight that it popped off once. The Fill/Drain ports are perfect, no problems there. You'll also see that my vent hose has some abrasion on it. The bag is so tall that it does pinch it a little against the bottom of the fiberglass and is rubbing the hose. No visible damage to the fiberglass or gelcoat, but the hose may need replacing someday.
https://i.imgur.com/UwbKomu.jpg
