You have LED wires at each speaker location or you have an overhead light on the tower?
At each location. I pulled all the plugs out in the tower and there were wires at every one. I downloaded the wiring diagram off Roswell to to confirm what each of them was for.
There's even wires on the sides of the tower for the LED accent lights you can add to the bases of the tower.
Any chance they did RGB wiring? That would be awesome!
https://roswellmarine.zendesk.com/hc...21-Nov-13_.pdf
This is similar for the Aviator 3 tower, but the 3 has more light output points not shown on this schematic.
I won't know more till I get my boat out of storage and dig into my install.
I'm moving from the 4 Roswell tower pods / kicker ks200.2 from factory to exile 30.2 powering 4 exile tower speakers. This setup needs the speakers wired in parallel. Do you all who have the experience know if the factory wiring setup is already in this config? In other words, I shouldn't have to change any wiring in the tower? This would make sense because the factory kicker amp is also a 2-channel.
You can wire in parallel or series right at the amp. No need to change anything inside the tower itself.
In other words, 4 wires from amp are independent to 4 pods on tower?
Wouldn't that mean there needs to be 8 conductors (+ and - for each speaker) coming out of the tower? The diagram you linked only shows 4 conductors and indicates the wires come into the amp compartment wired parallel.
In RE to the Exile setup. You should be able to use the 4 conductors from the tower into the 30.2, giving each pod 210w each.
Remember this is not the A3 wiring diagram. They have not published that yet.
On my Craz there's are 8 speaker wires coming out the port leg of the tower.
Then the light wires comes out the starboard leg.
