Couldn't agree more!! Makes me wonder where ole Goose has been?
Sorry, I'm so used to typing it like this I should have explained more. When I say 60/70 I am meaning 60% deployment of the starboard flow tab when surfing on the port side and then 70% port flow tab deployment when surfing on the starboard side. Same things for 45/55.
You should get your dealer to check out the amplitude gauge. Most likely something is going on with your draft sensor. This is the number one thing I watch when I'm using a boat, regardless of whether I'm using AutoWake or not. It's the key for creating consistent wakes each time you go out. This could definitely affect your Flow 3 system if you have a 2021 unless your dealer has programmed around it.
