I'm looking for a solution that doesn't involve welding. I see people have done it without welding but didn't describe how it was fabricated.
Where are you seeing that? My route involved welding 1/2" spacers to the oem plate, MLA solution is similar, but his weld is hidden (guessing a cutout on the plate allowing a backside weld).
You could thru bolt the Wetsounds base thru the spacer into the oem plate if you wanted, but I would for sure want a nut on the inside.
I had custom brackets I designed machined for mine, and now I'm having a hard time remembering if I was able to put a nut on the inside of the threaded plate. I'm pretty certain, if you thru bolt, the spacing is just enough to let you get a nut on the inside.
CNC milled starting with block of billet. Down side, it leaves quite a bit of material on the floor. But no welding involved.Quote:
They are two piece that are welded together. We wen this direct for the very reason noted above.
I know this is bringing back an old thread and probably a long shot but did either of you guys end up making a larger batch of your spacer solution for the sbend uppers that you would be willing to sell?
