Trayson ;
Question ... Did you drill a "drain" hole so trapped water could escape ? I just finished same setup as yours and read different post about a drain hole ? Thanks in advance.
Trayson ;
Didn't keep flappers.
No weep hole.
Found aluminum pipe that has the same outside diameter as the inside diameter of the screw in clean out tee fitting. Sealed it with gasket maker.https://uploads.tapatalk-cdn.com/201...e30e3ec580.jpg
Sent from my VS995 using Tapatalk
