Thanks.
Do you have flow 3? I have the same issue where its usually 10-12 digits off in either direction, when moving it gets closer but I assumed it had to do with the yaw plates moving around the boat being smarter than me.
An issue we had yesterday when surfing, if we use the manual switch to select port side surfing and turn the boat off, but dont flip the switch back to middle it will flip the plates on startup and deploy the starboard side wave. First time we had it happen when swapping riders we kicked the boat off then pulled a newbie up but the wave was on the wrong side, took a min to figure out what the heck happened. I could force it to do it every time we kicked the boat off and didnt flip the switch back to the middle position. I think we need to just start using the touch screen, or remember to kick it off when we turn the boat off.
