I tried that and it didn’t make a difference. I got it to match for a little bit but it reverted back to being off. I am wondering if it could be a voltage issue?
All of you guys that are having an issue with the setting being off....what position are you running your batteries in?
I run the switch down, which I believe is both batteries.
I run it on just one battery
2021 boats with the 7" screen have what is called displacement integration. The boat looks at the level of the draft sensor and decides where to position the surf plates in relation to the set point. If you turn AutoWake on, there are 3 levels of the amplitude display. If the actual displacement is in the lower third of the amplitude display, the Flow system will deploy at 10% less than the setpoint value (less weight in the boat means less deployment to gain lean). If the actual displacement is in the middle third of the amplitude display, the Flow system will deploy at the setpoint value. If the actual displacement is in the top third of the amplitude display, the Flow system will deploy at 10% more than the setpoint value (more weight in the boat means more deployment to gain lean). There is a way to adjust these settings should you choose to do so. See your dealer for those details.
Also on 2021's, if equipped with the dual battery option you should run on both batteries during normal use.
Yes. But I guess I should add on the Flow 3.... on the displacement integration it affects the deployment of the yaw plate (Flow 3.0) as well. If amplitude is in the bottom 3rd, the yaw plate will not deploy. If amplitude is in the middle third, the yaw plate will go to 50%. If amplitude is in the top third, the yaw plate will go to 100%.
