That's hot!
It’s basically a double board bag (2 pockets with reflective material on top) that folds in the middle and has an adjustable strap on each corner to attach it to the bimini frame. It also has straps on top of each pocket to attach another board (for a total of 4 boards).
I found it when searching for premade surf pockets to add to the Max’s bimini since they aren’t a factory option. It works really well for the price, it’s nice to be able to fold it up and put all your boards in the back of the truck at the end of the day.
Only 2 issues I’ve noticed: there is a non adjustable front strap for the boards that go on top of the pockets. At cruising speed this would start “buzzing” from flapping/vibrating against the board, but only does it depending on the board combo in the pocket vs on top of pocket and a certain speeds.
The other issue is that the fins on my doomswell make it a little thick to go in the surf pocket to keep it out of the sun. I can force it, but the fabric material with a drawstring is starting to tear a bit.
I’ll update with some pics in a day or two.
Can you put a "twist" in that strap like you do for bimini straps that buzz?
No because this front strap is fixed, no buckle or adjuster. There are 2 adjustable board straps further back on the bag.
A pic from the top:
https://uploads.tapatalk-cdn.com/201...6434538152.jpg
Maybe you can twist something around it to create the same effect.
Lake Berryessa and Lake Tahoe mostly!
Drove for some shop employees today and the MAX was throwing down. So ready to see what’s in store for 2019.
https://uploads.tapatalk-cdn.com/201...71d3f8344a.png
DFTR Josh
Moomba/Supra
www.marine-products.com
(Discount code: DFTR)
