Originally Posted by
MMPRES
Not sure which model you're referring to, but I have the 2016 Craz. I had this same problem with mine all last summer and had been consistently playing with this. I'm 250ish and need to have better push than others to do anything with the surf wave. I kept constantly changing variables of weight varying weight in the nose and changing the surf plate. I was weighting the boat evenly in the tail and relying on people in the boat and the surf plate to provide tilt in the boat while under power. But I recently discovered the problem. In order to get the push you need, you have to drastically list the boat to the surf side. Regardless of the people in the boat, the best way to achieve this is to have the non-surf side not completely full. I didn't even have the plate deployed, but the lack of weight on the opposite (starboard) side put enough of that side (port) of the running surface in the water to give me the push I needed. So before you spend any more money with upgrades, attempt full surf side, 50-75% off, plate 60-70% and 2/3-full nose and see how that turns out. I would hate to see you leave behind such a great boat due to you not being able to have some fun too.
