That acceleration is hard to describe - but it is da bomb.... And seriously - did you not feel you were in better position for the pre-turn (if you could handle the slack from the extra speed)? Do you remember where your eyes were looking at the start of the turn?
One of the things that we sometimes forget is that the hulls that are designed as three event ski boats (slalom, jump, and trick) are designed to have a large wake at slow speeds 17-20? for trick and a low wake at 36mph for slalom. So at 30 mph the 22 off bump can be unpredicatable from boat-to-boat, but it seems to be there for all of them. The new Nautique 206 looks like it may have conquered that however.
One of the things about a V drive is that the pylon is noticeably further back in the boat - probably as much as 6-8 feet? That will put the skier at a significantly different location in the wake and may make the bump noticeable even at 28 off... Probably why there is only one V drive sanctioned as a 3 event boat (and it is not a Skiers Choice boat)
