Originally Posted by
haknslash
How much engine noise did you get running it and what prop do you run now? I wonder if maybe I should try the 16x13 first and see how that does vs going straight to the 12.50?
BTW I ran the numbers today with full ballast, 500 lbs of lead, just me onboard, and I’m at minimum 10,670 lbs total displacement!! That’s unreal for the size of the boat. By comparison that is 869 lbs heavier than my 2019 Max with larger ballast bags. That doesn’t include gear and other crap. Pretty impressive IMO! Reduced fill and drain times are nice too!
