Yep that one came out great.
I miss having the physique to slalom ski. Used to love to hit the lake early in the morning to get that glass.
New to me '22 Mojo - we love it so far after our first weekend out. Attachment 31040
*Edit - I also suck at posting pictures. They all get flipped.
Ha! Trying tapatalk this time....https://uploads.tapatalk-cdn.com/202...1347e8146c.jpg
https://uploads.tapatalk-cdn.com/202...2c21605165.jpg
Nice and looks good!
Thanks! Now I just have to dial in the wave. I'm reading the 50 page thread on the Flow and it's already upgraded to WM bags in the rear and about 800# of lead. It should just be a matter of me learning the system as it surfed great on our water test with the dealer driving. I just didn't catch where he had everything set and we only surfed for like 20 minutes last weekend for the first time. Wave felt kind of flat and lacked some push. It feels close to being great though!
Did you run autowake when you surfed on your own? It typically comes factory set at a pitch of 8 which I don't think is high enough. You can go into setting and increase it. I set mine at 9.5. Distribute your lead such that with all ballast full and your crew in their different seating configurations, the boat doesn't drop naturally below 9 degrees at surf speed you should be good. Surf speed around 11.5mph. If you switch sides often distribution lead so roll is close to zero on regular side which will make it easier for the boat to achieve 4+ degrees goofie side. Factor tab settings are pretty good at 60/70 regular/goofie. I find depending on conditions you can decrease these settings a bit and get more push. Center plate 0-25. Higher pitch setting definitely increases height and push but increases engine rpm and decreases visibility. If you regularly surf regular, you can shift lead to help increase negative roll for further fine tuning.
Sent from my SM-S911U using Tapatalk
