What elevation are you at?
Maybe around 500 ft. Certainly less than 1000 ft.
Hey guys, 2 things, all good stuff, but some important information. First, I decided this time I was going to pay more attention to my surf tabs and maybe play around a little. Then I looked about to do goofy and the wave was messed up. This has happened before and I switched from goofy to reg, and then back, and most of the time this fixes it, but I noticed, the port tab (which makes the goofy wave) was at like 90, which I know isn't right. WTF? I texted 2 of my factory contacts and asked what defaults were, and I was watching, the port tab was changing in front of me, and I wasn't doing anything. So I manually set it to 70. 70 for port tab (makes goofy) and 60 for stbd tab are the default, and I played with them, and they work great, no need to touch them IMO. BUT, the goofy one was moving, I realized this must be why sometimes I get a finicky goofy wave, or inconsistent. So I paid attention, and sure enough, every time I saw weirdness, the plate moved. I paid close attention and kept it at the 70 which worked fantastic, and it was great. Not only was the wave great, it was consistent. So consistent, that my goofy roll setting has been 5º and I changed it to 4º. I could now consistently get a clean wave on goofy at 4º. I was ecstatic.
Matt told me there can be an issue with voltage that could cause this. He told me if I saw this happening, put battery to all, which should help resolve. Another good tip is to go to settings and retract the tabs at the begin of your session just to make sure they are fully retracted.
The factory is tracking this. I think this doesn't seem to effect regular so much, because if it does happen with reg, that side is just so much more forgiving.
Happy surfing guys. Luckily I am less than 10 mins from the ramp and going 1-2x per week and testing this stuff.
Oh, one more thing, at 4º on goofy, I noticed the wave had a better lip and J was getting bigger airs.
Picked up our new 2021 Mojo about a week ago. Wave was mediocre at best, OK push but very washed out. Dialed in the Wake9 pitch and roll but was still really sloppy. Finally noticed that the default surf tab setting was pretty far off from the the recommended. Default was 90, but when we set it to 70 (Strbd) for a regular surfer the wave really cleaned up / huge improvement. Much happier with the new tab setting!!!! Recommend everyone double check that setting.
However, I did notice that there is a ~10 degree difference between the set point and the reading. I saw mention of this in another post, but never saw a response. Any advice here?
Mine does similar on the settings being off. Some one else having same problem said when they used the screen to select surf side instead of the toggle switch, they matched. I was going to try this on mine this weekend, but got rained out.
