Originally Posted by
Jjdyn0mite
Ok, I had some time this week and put in a few hours on dialing in my wave. Just to be clear, this is my first real wake boat and I have only surfed behind one other boat, which was a centurion sv233 and it had a pretty crappy goofy wave. We are in south GA, so pretty close to sea level. I have the stock prop (1235 I think). I am goofy footed and my sons are regular. We were all able to surf with the stock ballast without the rope (settings were all ballast full including 500 stock IBS, about 10.8mph, autoflow at about 55, we usually ride with just my family when surfing, sof 5 of us and I'm by far the biggest at 6' 190lbs). I use trim plate up all the way, about 1/2 to 3/4 for the boys. The regular wave was decent, pretty good shape and clean face, just fairly short. My goofy wave was dirty no matter what I tried without listing, and very short. I am a beginner surfer and I felt like I had to work pretty hard to stay in the pocket unless I was right behind the boat, say within 5 feet of the platform. My boys could get back to about 5-10 feet and stay in the wave pretty well.
Anyway, as most of you have experienced, we wanted to make the wave better, so after reading some threads here and other research, I was able to come up with some 1100 fly high v-drive sacs to replace the 650's, and added the wakemakers panel savers. I have also been glued to the wave shaper/suck gate threads here and on the mastercraft and tige owners forums, so we built a couple versions this week to see if they would work on the craz/autoflow. So we got everything set up and went to get some scientific findings:
First, let me apologize for the lack of pictures, I am the only one in my family who seems to realize the importance of photodocumentation of surf waves...
First we filled all ballast up full, 1100 rears, 500 IBS, 700 center. Then autoflow settings were fiddled with. With this setup, we had a much taller wave with good shape on the regular/port side, but it was still dirty on the goofy/starboard side. We set cruise over 11mph, between 11 and 11.6, trim tab down 1/2 and it was definitely much more push than before. Had a real nice curl on the regular side. But the boat was really working hard, RPM around 3500 and even with trim tab all the way down, I had to stand to see over the bow. This was better, but not really what I was looking for.
What I found is that the stock IBS really doesn't give enough weight up front to work well with the upgraded rears. Ragboy at wake9 recommends 25-30% of weight up front, so I added a 400lb sac in the bow (I put it on goofy side bow seat) to give me roughly 900 up front, maybe a little less than 1/3 of my weight up there. To clean up the goofy side, I set the port rear to about 3/4. Speed was around 11mph, trim tab 3/4 to full, auto flow at 60 on goofy side.
THIS is what I was looking for! Clean face and the shape actually looked like a wave with a beautiful round base like I've seen in pictures, and not just a glorified rooster tail. I was free riding about 15 feet back (about where the rope ends). So much more push, I could stay in the pocket all day. Stock, I was working so hard, I could feel my calves burning. With this setup I rode for about 30 minutes and wasn't even tired, but I felt bad about not letting anyone else ride... The other nice thing about adding the extra bow weight was it was far easier to see over the bow and the engine was taking it easy at just over 3000 RPM. Only downside was I caught a big roller and almost sunk the boat :(
Last experiment was to add a suck gate. I made one that has the paddle in the back and attached it below the water line as far back as I could get it. Paddle is has a 20 degree angle and is about 9" x 6". By itself, I was not impressed, it just made a dirty wave with minimal shape. I turned on the autoflow and BOOM! This was probably my best goofy wave yet. The wave actually crossed the midline of the boat and was probably another 5 feet longer keeping all the other settings the same. This was pretty fun and had a huge face that if I were any good I could probably use for spins and tricks, but I'm not there yet... Downsides to the suck gate: 1. It was a bitch to control the boat at slow speeds cause it pulls to the suck gate side, and, 2. the engine was working pretty hard again, 3500 or so RPM so fuel economy would suffer.
My thoughts right now are that the upgraded sacs, extra bow weight, and suck gate gave the best possible wave available to me right now, however I'm not sure adding the suck gate is worth the extra hassle and fuel requirements. I'm pretty sure that I will stick with the non suck gate wave for my day to day activity and maybe add it from time to time for a little extra boost...
Here are my goofy settings (regular/port side is easier to set up and I think you could do it evenly weighted):
Port 1100lb rear sac at 2/3 to 3/4
Starboard 1100lb rear sac full (to overflow)
Center/IBS full (to overflow)
400lb sac on starboard bow seat
Cruise at 11
Autoflow 2.0 at 60
Water 10+ feet deep
I think this setup would make most people pretty darn happy, it sure put a big ol' smile on my face. I have never surfed a competition level wave, but I'm starting figure out what it looks like. I'm trying to figure out how to get the bow weight up without that big ugly sac on my seat. The IBS already pushes my cupholders out of the bow, not sure there's room for a bigger bag up there in the traditional bow of the CRAZ. I may try about 2-300lb lead sacs tucked as far in the bow as I can get it. Anyone else have any ideas?
