That doesn't sound to bad at all , will definitely be worth it.
Very nice! Impressive work.
Got the quick release pin conversion done, super easy to remove struts then tray , box anchor and bumpers with lots of room to spare , super stoked. And got the swivels on racks , was a good day for modshttps://uploads.tapatalk-cdn.com/201...b8a2b3d1c5.jpghttps://uploads.tapatalk-cdn.com/201...049fcdfadd.jpghttps://uploads.tapatalk-cdn.com/201...1af8f9cf8b.jpghttps://uploads.tapatalk-cdn.com/201...8cae38f743.jpg
Sent from my XT1254 using Tapatalk
I unscrewed the plastic end off the strut and went to the hardware store and got a rod end to screw on instead , the factory struts had metric threads so I did swap those with a set of struts from Napa then machined a mount for the quick release pin to go in , utilizing factory holes and hardwarehttps://uploads.tapatalk-cdn.com/201...7296e1b97c.jpg
It looks like There is still a ton of space available in the tray too.
There is for sure , that stuff only took up barely over half the space.
