Pics updated as per a couple requests.
I think I am going to give this a shot in my 05 LSV, however my center bag doesn't have a top vent, it only has fill and drain holes at one end. My current plan to handle this is to insert a Y or T fitting on the current fill line that will branch off to the new IBS and center sacs. Any ideas on if this should still work?
Use a Y fitting, it seems to split the water more evenly unless at absolute end of a run.
Add a vent to the center bag and tie in to the drain drain port.
Add a vent is easy .
https://forum.moomba.com/showthread....highlight=vent
Thanks for the link on adding the vent, looks very simple.
Also just so I'm clear, use a Y fitting from the new vent/fill line from center sac to drain on each leg of the IBS and that eliminates the need for the additional through hull drain and pump all together?
sounds right, but i actually plumbed in two drain pumps in my set up,
LSVboombox i believe broke ground on this so i will defered to him, but that seems right.
i was talking about drain line, i think lsvboombox was talking about vent line...
Thats what I thought, either way I am about to put my order in with wakemakers. The plan is to add a new outlet from the center sac and split it with a Y to each leg of the IBS, if it drains back into the center sac great, if not I will add some drain pumps.
I know Newty recommended specifically a spring check valve, but I assume the check valve wakemakers sells will work for this right?
