Originally Posted by
goose
Well, I have all good news. I have written 2 more installments that cover wakeplates and also how and when to adjust pitch and roll. I will be posting those shortly. Also, all our testing has been very promising and we have a firmware fix for any 2017 or 2018 Moomba models. In fact, it is all the same software. And that software includes all the new predictive logic and amplitude display that we included for 2018. If you have a 2017 model, then you will not have a draft sensor, so if the system doesn't see a draft sensor, then the Amplitude display is more like a graphic version of ballast gauges. If you have a 2018 model and it does have a draft sensor, then the Amplitude display works as designed for 2018. We are still experimenting with the idea of making draft sensors available for 2017. It is not as easy as plug and play because we had to change pickup locations to make the draft sensor work, so just know that right now it is not available, but at some point, it might be. If you want the new software, contact your dealer. They can contact our customer service department and we can email them a link to the software. In fact, the dealer should be able to email you the software also and you could probably reflash the software yourself. Another idea is if you use your dealer to winterize or service your boat, then that would also be a good time to get the software installed. Anyways, just wanted to let everyone know that the glitch has been corrected and for those customers with 2017 models, you will also be getting a free upgrade to the improved logic. Stay tuned for more tips posted shortly....
