Mine only sticks the first time when the boat is dry, after everything is wet I can't get it to stay on again...
That's some customer service right there!
Thanks Dan, let me know what you need from me for shipping costs, etc.
Taft
Will do. For the record and anyone wanting these, the wave was badass when it stuck.
Put me down for one, once you get back up and running.
Sorry to hear about some guys having issues. I'm in the middle of moving so quickest way to get back out there will be to pick up this handle at Home Depot and swap the cups. There are some similar options on Amazon as well. I'll reimburse you for the cost of the new handle.
https://uploads.tapatalk-cdn.com/201...d91226dd67.jpg
Amazon option:
Grab Bar by Vive - Suction Shower Handle & Bathroom Balance Bar - Safety Hand Rail S... https://www.amazon.com/dp/B01G48KSK8..._MWEFzbG6162FW
Yup, same problem here....mine will not stay on the boat :-(
Dan, Sent you pm about handle replacement.
Any before after photos on a craz?
For anyone having problems with the gate coming off - make sure you do not get any suntan lotion on the suction cups. Even just touching the cups hours after applying lotion can cause problems, which can happen when switching sides trying to peal off the cups. A month ago we switched sides 3-4 times successfully, then tried unsuccessfully 4 times to get the gate to stay put - finally giving up for the day. Prior to the next trip out I washed the cups with dish soap and cleaned the boat side. I made sure to washed my hands after suntan lotion, then made sure no one touched the cup face. We have not had any issues since. Happy surfing.
I recommend finding a way to attach the wake shaper to the rear eye on the boat. Just be sure to do it in a way that the recoil action doesn't land it into the boat.
We lost ours this weekend on a small but busy lake. By the time we noticed it was no longer attached to the boat, it was long gone. It was attached to a fender buoy. Problem: mine was white, like every other buoy out there. Should have used yellow or orange. We had to look closely at every dock and raft, but still no luck. Never found either the shaper or the buoy. Either a prop got the buoy and the whole thing sank or someone found it and kept it.
Does anyone know how to swap the cups?
