From my research, the evolution tabs are completely manually operated buttons. There is no CPU/programming to have them retract or launch based on GPS or switching sides. That is the posh part of the other systems and since you are paying 1/2 of the cost I would not expect it either. GSA and similar systems also have memory where the tabs are deployed and return to that position each time when activated, so repeatability is there.
Not downing either system, everyone has their price points and myself does not see spending $5k for GSA at the moment either, but Wakeland system is the same price as evolution and has similar function to GSA. Wakeland is the OEM for Skier's so the plate design is factory Autosurf 2.0 I just wish the Wakeland system would integrate into the factory screen since everything is already in the harness and the programming is already in the screen. Just add the sensors, GPS antenna, plates and relay board. Make it all plug and play since 2015+ boats had Autosurf as an option.
