I STAND CORRECTED. [emoji1365][emoji1365]
(Get the 18s if weight capacity is your only concern).
kaiyen will fit ONLY with pro tower AND 15's. would assume mojo/makai/mondo would but a quick call to drew told us about kaiyen so sure they would answer on other boats as well.
sa/sr will fit with 15's. there are a couple that told us boardracks would have to remove and a couple that said they didn't but both dealers that had sa's on the lot taped both 15's and 18's and told 15's were close, 18's were out.
there are quite a few boats that will fit under 8ft doors from several different manufacturers including tige, mb, moomba, supra, supreme, sanger and guessing heyday but never comfirmed it.
there are still a few boats out there that will fit 7ft doors but they are getting rare.
yes, I was only concerned about WEIGHT (because of lead)... no way a boat would come close to fitting, even though I have a 3 car garage..
We have a 48" outdoor storage that we pay for each month.. :( in fact, In the 3 years I owned the max, I never once put the tower down!
18's it is!!! Decision is made! thanks guys!!
18s unless you just don’t want to drop the cash
Also you should not that the GVWR of the trailer being 7500 lbs INCLUDES the weight of the trailer too. You can not put a 7500 lb boat a trailer rated for 7500 lb. My 2017 Mojo on the trailer loaded with 200 lb of lead and full fuel and everything we need for the lake is 6940 lb.
https://uploads.tapatalk-cdn.com/202...16b1e8b3a9.jpg
https://uploads.tapatalk-cdn.com/202...8f0374a7b2.jpg
https://uploads.tapatalk-cdn.com/202...74b7b2bcb7.jpg
https://uploads.tapatalk-cdn.com/202...2ad9b5bd9f.jpg
Great pics. Too nice to get that wheels dirty . . .
gooooliiiiee... that boat is hot. wheels look fantastic!
so.... website says 2021 mojo is 6,000 lbs boat and trailer.. if we add 500 lbs of lead say, we are at 6,500. 70 gallons of gas = 441 lbs.. = 6941. plus coolers, etc.
850 lbs of lead would be - 7,241. Pushing it, I would say.. have to assume that the Mfg. limit listed is being cautions (of course) .. but I dunno.
