Not too bad, and you have the only Max with Flow 3.
I find it really odd that it has to be 2020 or newer. 2018 had a Mojo Pro with 3.0 and 2019 had a Craz Pro with 3.0.
I have a 2019 Mojo and would love to try out the 3.0 on it to see if it cleans up the lip. @Dakota - How did you hear about it only on 2020 and newer?
The reference to 2020 was the year that the 7" touch screen became available on all boats and the 7" screen is required for flow 3.0 so I would say that the older pro models with flow 3.0 would have had the first available 7" touch screens. So in reality it is less about the year but you need the 7" touch screen and the older pre 2020 boats would not have the correct screen unless they had flow 3.0 at which point you already have it so ....
That makes sense, I got the 7" touchscreen on my 2019 Mojo...so could add 3.0.
@Dakota; curious on if anything needs to be updated to the Software or if it just engages?
There is a wiring harness that plugs into the PDM on the starboard side of the boat. There’s only one empty port and it’s for 3.0. Premade wiring harness plugs right in. I’m out on the water and will post images in a little while but the difference is astounding.
looking forward to seeing some the pics!
I am a quite a large man. The length increase is remarkable, especially at this heavy ballast weight. No weight cheating required to make it clean as a whistle.
All this size is at 12.0 MPH.
I really did not expect it.
https://uploads.tapatalk-cdn.com/202...39433ff5a5.jpg
https://uploads.tapatalk-cdn.com/202...39bd13ca03.jpg
That looks glorious. For reference, how much ballast weight are you running? Did you get a chance to ride/transition it to goofy side? That flat/buttery smooth wave face is the end game for sure. Nice job.
Dang.....that is sweet!
https://uploads.tapatalk-cdn.com/202...f7524bffe1.jpg
https://uploads.tapatalk-cdn.com/202...3b8f4754e2.jpg
