Originally Posted by
Bmac
Does anyone know if the go home feature can be put on a 2020? I have the small screen if that makes any difference. I have played around with the 3 plate launch and there are a few things that really bother me. So right now without the go home feature I turn autowake on, set amp to 0, and turn cruise on and the plates deploy just like they should. The problem is that my bags are full at this point and I want them to drain while I head back to the dock. I can’t remember the speed but at a certain speed the plates go back up and then I can’t hold the speed and I go back and forth to the point I get sick of it and I never use it anymore. If it drained the ballast while I got on plain I think I could keep the speed all the way back to the dock. I haven’t tried it but wouldn’t the plates pull back up if you flipped a ballast switch while autowake is on. I know it gives you a screen that says autowake can’t run while ballast is draining or something. If I could manually drain ballast and still get the three plates to deploy I would be really happy.
