Originally Posted by
Mwcraz
I think a couple things need cleared up. First the suburban with the heavy duty tow package comes with a hitch rated for 10,000lbs and 1000 tongue weight. It says right on the hitch. The truck is not rated that high but the hitch is. Second the F150 is more confusing. Without the weight distribution insert and bars it is 500/5000. With weight distribution it is over 1000/10000. Anyone towing a large camper would definitely want to use this setup. It does not reduce the overall pull on the hitch just places more of the trailers weight on the trailer axles. It also helps with stability. The bigger issue people miss is payload. My Tundra had just over 1200lbs. When you add 600lbs of tongue weight you only have 600 left for people and gear. This is a much larger concern as many of the trucks exceed their payload. My F150 is 1600lbs. Also a class 3 hitch is up to 8000 and a class 4 is up to 10,000. You are fine towing our boats with a class 4 just don’t overload the truck’s capacity.
