No, I was replying to your post a couple ^^ about the windshield. Lol
Too many conversations going now.
Pictures would help to understand the windshield issue.
The windshield separation issue was the biggest problem with Moombas back in 1998 and nothing much said after that until now. The curved windshield top frame would pivot up from vibration and there was only one screw on each side of the mounting to the side frames allowing the frame to pivot on the single screw on each side. The problem was with the observer side windshield and allowed the walk thru windshield to separate on the driver's side. I solved the problem by adding a small screw to the passenger side frame where it connects to the side frame to prevent pivoting. The windshield got out of alignment every time I hit a hard bump and the screw fixed it. Also the inside supports need to be solid with no movement.
So far they did get the swim pad and the front now step area covered for the pads coming up. Now they are trying to figure out about the window. Luckily I have a great dealership. Next new boat I will read all the exclusions on warranty. They also ordered me the engine tray.
Good to hear. What dealership?
It’s regal nautique of Orlando in Florida.
Just to update. The dealer was able to get everything covered under warranty. Just picked it up today and everything looks good. Also ordered the engine tray while it was there.
Found a new problem today when I got home though while getting g it ready to be put up for the winter. I’m sure others have the same problem and may want to check. Probably applies to more then just the mojo. Port and starboard sundeck cushions are getting a hole worn in them in the exact same place in each side. The cushions are rubbing on the welt cording of the center engine section. I’m going to report it for warranty and see what they decide.
https://uploads.tapatalk-cdn.com/201...c42c82ab02.jpghttps://uploads.tapatalk-cdn.com/201...ac0afa76d5.jpghttps://uploads.tapatalk-cdn.com/201...3b9e7e2e51.jpg
