I purchased a tray from the dealer that fits the 2019 Mojo. I'll post pictures of it when it comes in.
The question is then, which tray (part number) did you order?
The part number is in the second post of this topic
Does anyone have a good dealer to buy from? Mine won't get back to me?
So I bought the same one for my 2015. The newer boats use 2 struts to hold the engine cover up. My 2015 uses a single strut mounted to the front. I just removed the strut from the quick disconnect and cut a slot in the plastic tray so it would fit over the mount. Then reattached the strut. They are quick disconnect strut ends so very simple.
You could replace the single unit with duals like the newer boats but the tray is already $200 and I didn't see the need. As for you 2014, if the hull for it is the same as 2015 I know it fits the hole.
Ordered mine today - wow they have gone up! $272 from local dealer. I will be the first 2014 fitting one but if measurements are correct that I see in this thread it will fit just fine.
It will fit jist fine. You only have a single strut verses the double strut of the newer boats. You can either cut a groove in the front and make it fit around strut mount OR change to a dual strut setup.
Whichever you chose make it easy to remove. You cannot do any maintenance items with it installed.
