I am interested in this as well. Any pictures of one cut down? I don't think removing it is a viable option.
I just cut mine down last week and it was pretty easy. Didn't worry about getting things too perfect. I will try and get a picture. I didn't think trying to remove it was worth the time and hassle, it's not like anyone sees it under the boat.
Sounds like I’ll just cut it as well. Good reason to buy a Dremel.
Has anyone reading this plumbed a fill/drain line to the second leg of IBS? I saw someone mention some residual water getting left and having to “lift the leg”, was thinking a y connector would be the easiest way to get this done just curious how you actually routed the hose in the boat? My guess was around the bow along the IBS bag.
So how do you plan to route the hose for the port side leg of IBS? What I’m thinking is either come up through the hole where battery cables run in passenger compartment or come up under helm on starboard side then y and run second line around front of bow/IBS that way?
My boat is in storage so there plan might change when I do the work in the Spring but I plan on a Y pretty close to the bag and separate lines to the IBS legs via there shortest route possible. Might have to drill holes in the floor. Right now I have lines going from the ski locker bag the l to the IBS thru the hole where there battery cables run and under under the console. One files and the other drains
