400lbs under the seat where the cooler is. The inside is located under the front seats bow around 600lbs.
I use one of these on my 08 LSV. It's been awesome. I installed the "gate" part on the back and install it as low and back to the transom as you can. Regular side sure equal weighting all ballast full. Goofy side starboard full and port 75-80%. Speed 11.7
I didn't have an IBS when i first started using it so I had to keep my wakeplate nearly 100% deployed.
1100s each rear, 500 ski locker and now 500 bow.
Speed is the trick with the delta.
