Plugs will tell you if you are burning coolant but consuming the whole tank in 20 seconds would be hydro locking your engine if it was getting in a cylinder or 2.
Sounds like a hose is leaking, but would expect to see coolant in the hull.
Trying to think if any closed loop coolant hose dumps straight to exhaust/water jacket.
Leak in heat exchanger? That would dump closed loop coolant.
