I just cant see temperature change causing that indention. Also I would have to assume that if it was an impact or something that happened suddenly wouldn't the fiberglass spider web?
So just heard back. Looks like it is going to be repaired by local shop in a couple weeks. They will be doing work on the glass to smooth it out. If all goes well, I will be launching late March with this all as a faint memory
Good news. Do they have a reason for the issue?
I don't want to be guilty of misquoting anything as that can be a dangerous thing but he said they have seen it happen before and it had to do with the glass curing. I didn't go too much further into it, just happy it'll be taken care of
Very interested to know the fix, what they do exactly. Is the dealership covering this or is Skiers handling it under Hull warranty?
Glad to hear they are sorting it out for you.
Did you have a look behind the amp rack to see if it curved in or is that a 2nd skin so to speak?
Sounds like a temp issue and improper curing at the time of manufacture, thought it may be worth putting some pressure from inside outwards and leave in the sun for a bit during a warmer day.
Regards BruceR.
I tried peeking behind but nothing obvious. It will have a bit of time to sit in my garage for a couple weeks so we will see what it does before it hits the shop. It's weird this happened but semi comforting to know it has happened to others and not just with SC boats
Glad to hear they are taking care of it
