Surf Setup - 2016 Mojo - HELP!
Quote:
Originally Posted by
Ruzzbutz
. Anybody have any advice on how to piggyback bags? I was just going to run a line out of the overflow of the 1100 to fill it but not sure how it will be able to drain. Thanks.
I just ran a short section of hose with fittings from the bottom forward edge of my 1100 into the bottom edge (former fill) of my stock 650. Then I capped the overflow of my 1100 and re-routed the boats overflow into the stock 650. You'll have to watch the 650 though as it will push your seats up if you wait until the overflow starts to run out the Side of the boat. It took me a few fills to bleed all of the air out of the bags too since the 650's are too big for that space. Just make sure the bags are oriented with a plug in an accessible spot before you start to fill them.
Funny because I feel like I can't get enough weight in the front.
We all surf goofy and I run probably 800 on my starboard side and 500 on the port, center full and 500 IBS full. With that the wave was tall but not long enough. Now I do all of that plus add my old 650 IBS on top of my bow seats. That helped lengthen the wave considerably.
The regular side I've yet to figure out (ask russellsmojo)
Woody929
Haha. Could be rider error!
Woody929
Funny because I feel like I can't get enough weight in the front. )
I hear you. I just bought 300#'s of sand bags from Home Depot tonight to supplement the 750 IBS next week when we're back at the lake. Going to move them around and see what works best before I decide to invest in a more permanent additional ballast solution. I really wish the IBS had longer legs, I've got plenty of room up there under the seats.
We've had the best luck with everything full (hard tank, 750 IBS, 1100's and as much of the 650's under the rear seats) and fully deploying the auto flow, wake plate 100% up. Did have to dump some off the rear offside to clean up the goofy wake. Wave looks good, massive right behind the boat, hoping more front weight lengthens it out.
Ruzzbutz
Thanks for the info - my 1100's don't have any fittings on the forward side though, just the fill and drain ports on the back side and the overflow on the top. Maybe I need a different type of bag or am I missing something? I have the flyhigh 1100's I think.
I believe I bought the Wakemaker branded 1100's. Several different holes to plumb into.
