RMK818-Single ghetto Gate
You can see pics of my gates earlier in the thread.
As for the wave, I can tell that it's better but not remarkably so. I'd say like a 30-40% improvement. My biggest gain is that I can fill both rear sacs and not have to drain and fill every time we switched from the regular to the goofy side.
Not much I would do differently except to use a somewhat thicker material as both of my gates broke in the same place but have been fine since I doubled up on the cutting board used on the piece that's up against the transom.
So here is the wave I am getting from my ghetto gate. http://images.tapatalk-cdn.com/15/08...f6697d1750.jpg
About 2 400lbs of ballast and just driver.
Here is a quick video of my wave with the gate.....not great cause I'm in the boat by myself but got bigger with a few peeps as well as my upgrade from the 750 sac to the 900. https://vimeo.com/136237996
Here is version 1. There are still some issues but the void it creates tells me it's doing something. I have the stock platform. I need to add something between the hull and the gate to prevent spray. All 3/4 inch plywood and 2x4, wrapped in marine vinyl I had laying around.
http://images.tapatalk-cdn.com/15/08...5b3b37cdce.jpghttp://images.tapatalk-cdn.com/15/08...debe74fb56.jpghttp://images.tapatalk-cdn.com/15/08...7937dd144b.jpghttp://images.tapatalk-cdn.com/15/08...d212d278e1.jpg
