I'm sure that's what's happening with mine. So essentially they're worthless, hence the ball valves.
With any check valve, it would be an unconventional application. We tried it and have been using them for this. So not only do we get a more complete drain, we have addresses some passive draining.Quote:
Interestingly, anti-siphoning via the vent is not listed as a possible application.
MLA sent me a couple of his check valves. They are very slick, and work much better than the Wakemakers valves. The WM valves require quite a bit of pressure to close the valve and prevent backflow. MLA's do not. I'll be giving them a test next week hopefully.
Looking forward to hearing your experience with them. let us know after you get a few trips with them.
Any update on the check valves?
I didn't get them installed before the end of the season. They'll be on before the spring though.
@Shoebox
Has the ice thawed?
Hmm... Nope. [emoji24]https://uploads.tapatalk-cdn.com/201...0d0e8b007b.jpg
