I agree a lot of the draw is that its the newest thing. I definately think airs are possible, maybe not for someone my size but down at Middleweight perhaps lol
I've found that the trick to surf foiling (as opposed to riding at wakeboard length) is to stay 3ish or more feet away from the actual wave (assuming the first wave, not several back). I kept getting launched when thinking I needed to ride in the pocket like regular surfing, but had no problem the first time I wandered further from the wave. Even with no ballast the wake has so much push that it will launch you out and you won't be able to burn off the speed and recover (until you are really really good, then you'll do it on purpose). I ride (have a Slingshot Infinity 84) with surf tab at 9.5mph and once you find the sweet spot you can ride straight all day long and slowly work on carving to gain and lose speed.
I got the original slingshot Wakefoil and it’s a blast. I’ve almost given up surfing for the most part... took me a little bit to drop the rope, but it’s a blast once I figured out how far away from the wave you can go, or riding the second wave back.
I passed the slingshot on to a friend and now have a full carbon setup... 200 wing on a 29” mast. Game changer to say the least! Our goal this summer is to get multiple surfers on both regular and goofy, will post a vid if we get it done.
https://i.ibb.co/rQ6MvBx/JKz-GDQua-SF-Dhluh-Qswz-IA.jpg
How much for a carbon setup?
If you watch for deals, around $1000 for the foil setup. I’d recommend going to foilmount.com and getting a board that makes the most sense or buying that new singshot wf2... or finding a rep that can get you a deal. I have a couple boards that I use because I also take it to the ocean and surf the small stuff with the same foil.
I have the slingshot wakefoil setup with the standard wing (H5 wing I think? it's the blue one, LOL). What setup would you recommend for surfing?? How far forward or back should I mount the mast on the board? Should I use the 24" or the 30" mast? How much ballast should I use?
Do you think it's really worth the money to get a bigger wing? or is my wing just fine?
https://cdn.wakemakers.com/media/wys...FWake-Foil.jpg
Like I said, I can comfortably ride at wakeboard length, so surfing is the next thing.
The bigger the wing the more lift... so it just depends on what you want to do. i am able to pump back and forth to ride both sides, and I am trying to figure out best way to ride 4th and 5th wave back. I would read this and see what would best suit you, but the best thing would be to master that H5 either way while you have it.
(check chart at very bottom of page... its very accurate for the ones I have ridden: http://www.mackiteboarding.com/Foilb...Fridays-Ep-01/)
As for setup, I am running between 11-11.7, weight it evenly so both sides throw a killer second wave specifically. I rode my Slingshot behind a G23 fully ballasted and it just wasnt all that fun. Too much bucking/throwing.
Definitely try surfing it outside into the flats... you will find the push is in a weird spot, and then you use the carve to slow it back down as you come back into the wave. I spent way too much time going forward and back, and I should have been more concerned utilizing all 360* of the wave... very different from just wakesurfing alone.
The next toy on the list is a slingwing... been watching prices since others have released theirs (Naish, etc), but I have a pro deal that hopefully comes in June. Will be fun to use when the winds pick up at our local lake.
Slingshot is just a few hours away from me. I know a guy... that's what allowed me to pull the trigger on the wakefoil. I even drove out to their warehouse and picked it up to avoid big dollar shipping costs. (skip shipping and give the warehouse guy a 6-pack).
Still enjoying my Slingshot foil. Any better suggestions for storage/transport? The bulk of the foil inside the boat is the only downside.
https://uploads.tapatalk-cdn.com/201...6bc508d143.jpg
https://uploads.tapatalk-cdn.com/201...12ba333c5b.jpg
