It’s only been on for a day so I don’t have a good review yet. I think that the increased angle on the front CV joints can cause them to maybe wear out earlier. I think if I were going to do it again I would use the next setting down in the struts instead of the max lift. The front ended up being almost a little higher in the rear and I had bump the unloaded bag pressure from 5 to 15 psi to get the rear about 1/2” higher than the front. The ride doesn’t seem worse and I’ve heard the 5100s help when towing even.
