Originally Posted by
squeeg333
I've got a little question for you all. Just some food for though, or ideas of what others have done. When winterizing this year, I had the plugs out, and sprayed the fogging oil in the cylinders as is recommended, then turned the engine over a few times to lube the entired cylinder. Well, the pistons pushed some of the fogging oil out, enough that it got on the lowered engine comparment doors, and a little on the rear compartment carpet. This wasn't a huge issue, as it cleaned up easily with some simple green - but I am just curious when winterizing by yourself, how you guys kept this from happening -or did you?
