That was my question. How tight does it need to be, I have mine a little tighter than finger tight.
You will create an air pocket if you reverse the scupper, also the holes will not line up if you reverse them and you will have to put 4 more holes in the bottom of your boat. I asked the same question to wakemakers, and they said reversing the scupper was not recommended because of the air pocket it would create.
I can say, when you grind off the scupper it works great.
I purchased all my brass fittings at Home Depot, not sure what you are refering to about the brass bard for the shut-off valve. My ball valve is threaded to a 90 degree bend off the intake.
If you run your boat in mercy/dirty water often you could always add an inline filter. After an entire year of running my stock Supra ballast system I had very little debris in the filter they had on the stock system. Not that it could not suck anything up and ruin a pump, anything is possible. I elected not to re-install the filter again because of space limitations and its another source of friction loss to decrease your flow rate.
