WOT RPM Too Low - major issue? cause?
Quote:
Originally Posted by
Holdmybeer
Doing all these runs, the engine isn't mis-firing? No obvious mechanical issues?
This all seems to be electrical based on everything you have checked, just wanting to confirm. Could the TPS sensor be degrading over time? The fact the tach didn't work in February could be part of the issues. What did you do to fix that? Loose ground behind your gauge cluster?
no obvious mechanical issues i’m aware of.
don’t think there’s a misfire but not sure how to confirm easily without mefi scanner (no cheap options i’m aware of). plan to look at the spark plugs and if that may give me clues.
regarding tach at one point early in season i had a loose ground at ground bus behind dash causing some other intermittent issues but that was fixed. the tach still didnt work though. had a mechanic look and couldn’t figure it out said grey wire had continuity front to back, i tested a new tach still didn’t work (had some voltage but apparently not enough so thought the signal was there when it wasn’t or wasn’t strong enough), neither analog or pp rpm gauge worked (both off same signal). after looking at connections and disconnecting reconnecting the main harness behind the dash and then the 16pin plug at engine iirc, it started working so assuming it was a loose connection.
yeah could be tps or maybe throttle linkage as noted. not 100% sure how to confirm throttle linkage is working as expected. but if it moves all the way and past the ~80% point where throttle moves but doesn’t increase then yeah i should test the tps. is it just one at the engine or also a sensor at the throttle lever?
also a little confused - my 07 is drive by wire hut maybe still has mechanical linkage from throttle to engine. does that mean it does not have electronic throttle control full drive by wire where there would not even be a mechanical linkage just sensor at throttle?…
