Originally Posted by
RUGER761
Are you only hearing the sound at idle in forward or does it do it in reverse as well? If its not your seal making the noise, it could also be your prop. If you hit the prop on a stick or something in the water, it might be just slightly out of shape, which sometimes causes the prop to make a noise at idle or slightly above idle, somewhat technical name called "prop singing". Kind of has more of a harmonic type of sound. Goes away with more RPM and wont generally do it in reverse.
