Got it. Makes sense that at a hit higher RPMS more fresh water gets pumped and temp drops a bit.
Going to keep troubleshooting
We had the codes, the dealer replaced the sensor. Fixed that issue, have / had the coolant leak as well. It is due to the heater leaking. The dealer can put a dye in the hull and detect if its from the pump. We had the dealer disconnect the heater for the time being.
Update. At the boat today looking for the coolant leak. As the forum pointed out coolant syrup on bottom of heater pump. Most of the witness was in dead bottom where an electrical module is. I tightened both the threaded fittings and the hose clamps. Will see what changes next time out. Question- with the wetness not seeming to come from the fittings, is the actual pump known to leak? Pics below for reference
Yeah, later last weekend after tightening the clamps and fittings went out with a rag under the pump and it was soaked in coolant.
I’m still out of town for another 10 days or so. I’ll update y’all once I get back if I’ve lost any more coolant or if the pump is leaking. I’m gonna place a rag underneath and run engine and heater and see what’s up.
