I do not have this installed.
My 2015 system is slow and doesn't have your issues.
Check another thread. Guy did this to his Max and works great.
So my issue with bags getting air in them continues. Adjusting the timer seemed to help
But didn’t eliminate the issue. After 3 or so cycles there was a substantial amount of air in the bags.
I going to have a chat with the dealer and most likely start working on auto venting.
My question why don’t the auto vents work in the Enzo Fatsac vent the air as intended? Especially since there are few in each bag.
Any ideas?
https://uploads.tapatalk-cdn.com/202...92e1451dfe.jpg
2 things guys:
1) It is NOT a weight sensor...but a sensor on 2019 or newer that detects waterflow coming through the overflow(overflow is bottom of the bag). It resets the computer with a little red dot....nothing to do with weight...has to do with pressure\water flowing through the overflow.
2) Those little diaphragms - Those come on both stock bags and WM upgrade bags....they let air out slowly throughout the day....but 2 pumps on G6 won't vent them quick enough...they help more throughout the day!
I have all of my parts to upgrade my Makai to the WM 1345s in the rear and I am putting a top vent on the bags that ties into the over flow as Haknslash has done in the link below. I have pulled my rear trays (for sale soon LOL) out of my Makai as I have to burp the bags every time and getting to the fitting was a pain with them in there. I am also going to be putting check valves in all 4 of my overflow lines as this will help minimize air pulled back in to the system and help to fully drain the bags as mine are never completely empty and usually hold 50ish lbs of water. Check out Haks thread here and it might help you out.
https://forum.moomba.com/showthread....nting-tutorial
