Dnixd99 is spot on, it is the front one I took a picture of and yes that is the thru hull.
I did end up extending the wires on the sensors in the rear but that is only because I ran the vent hose from the top of the bag and not the back of the bag like it is stock.
And it didnt make sense to run the hose all the way back to the rear of the boat and back to the thru hull.
The one benefit of running the vent from the top of the bag is it less likely to get air trapped in there. Moomba has the vent caps which probably work fine but since I was already running a vent on the mid ship bag, I just tied the rear bag into it.
If you do run the vent from the top just make sure to strap and position your hose where it doesnt get squeezed between the bag and side of the boat when filling.
The bags are so tall it is easy for the hose to get pinched as it is filling up and pop off the connector. It kept on happening to me until I rerouted it.
I would imagine this is one of the reasons Moomba ran it from the back of the bag and lower.
Sent from my SM-G960U1 using Tapatalk
