Couldn’t resist waxing and sealing it over the weekend. She’s ready to shine on the water. Mighta even gave the trailer a little shinning. Now just waiting on numbers to come in to go with the bright orange stick they picked this yr for registration [emoji37] Ah well Warner weather is coming soon or at least soon enough for my wetsuit [emoji41][emoji2101]
https://uploads.tapatalk-cdn.com/202...8179e7fd91.jpg
Also pulled it out this weekend to test the brake lock out with a new fuse. Worked perfectly.
Forgot to post a truck pic the first day
https://uploads.tapatalk-cdn.com/202...3933e48c0c.jpg
If you ever blow that fuse again, boatmate should have given you the key that locks out the reverse mechanism. Snaps in, no tape needed.
The key was missing from the owners packet. No big deal now that I know which fuse it is and put spares in the truck. I actually know why it’s blow. One of our old trailers keep having grounding issues so I added a second ground to it using the reverse pin (the older trucks/trailers never used it, was always blank) so it’s that trailer that blew the fuse. Now I just need to remember to fix that trailer next time I use it. Typically only use it once a year.
