Yes I have a 2014+GM. My local trips are fairly short but a couple times a season we'll travel around 3-4 hours. So just curious how much better it might tow.
Although non-ethanol, regardless of the octane rating will provide substantially better fuels mileage (octane rating has nothing to do with power) most of the non-ethanol fuels being sold do not have a detergent package. Over time this will produce carbon build up on pistons and will restrict fuel injectors. So besides paying more for non-ethanol fuel; you’ll need to kick in for a good fuel detergent.
If you do use non-ethanol fuel in your boat, add Techron or other detergent package at every fill up.
Octane rating CAN absolutely has something to do with power IF tuned to take advantage of it.
General rule of thumb, for each point of octane, you can add appx 1 degree of timing which on a V8 engine is appx 8-10 additional HP.
Using 93 octane in an engine tuned for 87 will gain you nothing.
except an empty pocketbook :)
that's the point to the OP. use the lowest grade fuel you can use per the engine manufacturer.
my thoughts have always been use 89 as that's what the manuf. of my last 2 boats called for and since these are car motors using plastic tanks no reason to worry about ethanol or non ethanol UNLESS it's the end of the season and going to winterize. then I try to find a non-ethanol source and don't care if it's 89 or premium(91-94). the last couple of seasons tho I have not been able to find it within a reasonable distance so I filled up to the brim and used the suggested dose of sta-bil and have not had any starting issues. this living in wisconsin where I would typically winterize in mid september and lucky to get it out again by may.
In the context of this thread, a boat using an OEM ECM, there is no power benefit to running a higher then recommended octane.Quote:
Now, in the custom world, there is a benefit to using higher octane. But in reality, the BTU from different pump octanes is about all the same. The benefit comes from the proper ignition point, as the higher octane resists self-ignition due to the added heat of a higher compression engine.
Not necessarily there’s a reason why Walmart and Kroger fuel is cheap because it’s crap and bottom of the barrel. Most manufactures will give you a list of top tier gasoline manufacturers they recommend especially if you are running a direct injected engine. Firm believer in shell and Exxon and chevron etc, I’ve seen what cheap fuels do too engines https://uploads.tapatalk-cdn.com/201...c016da1c91.jpghttps://uploads.tapatalk-cdn.com/201...49c79e0197.jpg
