I can see what you are getting at, but you are looking for a long ways around solution to get there. When we say run some ballast to clean it up, the key word is SOME. it might take as little as 100 pounds in a rear bag to even up the wake. You could also simply ask your passengers to move a bit to clean it up. Do you run any steel shot bags? I always kept 100 pounds near me on our Mojo and moved it as needed to get the wake dialed in. Yeah, if your entire crew is sitting on the port side and only the driver, either add some weight to offset or ask them to move while people are riding. Way simpler and cheaper and I really don't think go home works below 21mph or so. You might be able to download a current manual to do some reading about the system. Remember, add weight to the washed side or take away from the clean side. Good luck!!
