Lol...that works for me.
Ryan
2017 Craz
Houston, TX
Ryan
2017 Craz
Houston, TX
On the windshield issue, that hinge wire should be able to be pushed up and out maybe 1/16”. Have some one hold it on the bottom side with a punch, and take a punch and hammer and hit the wire to slightly mushroom out the top out. That should stop it from sliding down, those wires are not hard, usually pretty soft metal.
That way there’s nothing to grab your hand and hurt anyone, but it shouldn’t slide down.
That would be my fix, and honestly what should have been done from the factory. If it ever needs removed just pull it from the top.
Is this issue on the Taylor made windshields on the Supras?
Not trying to hijack the OP's thread but I am in the process of ordering my boat and I have spec'd it with the transom remote, is this a mistake? Is everyone having problems with it and for those that are having problems with it does it affect the function of the main unit? Would you spec it on your next boat? TIA
I had same problem with Fusion transom remote volume fluctuating. 2016 Craz. Replaced under warranty when I had it winterized and serviced this fall. Fusion products have a three year warranty straight from Fusion. My dealership took care of it no questions asked and it fit exactly in spot already there. Not that I have had a bad experience with my boat at all, but from boats, campers and vehicles in the past, I have learned it is better to have a lemon and have a good dealer to work with than to have a good product and a terrible dealer to work with!!
So far I haven’t had an issue on my Supra or have I heard of one. Guess it’s just a Moomba thing?
