The Engine Nut has spoken . . . . .
Thanks for the insight, I've followed your advice on the mc forum as well. The acceleration issue was resolved with new plugs and wires but check engine light returned. The check engine light returned after being on the boat afew minutes and the voltage gauge read 16+ when accelerating. Got a new alternator in and hoping it was the voltage regulator otherwise she'll go in to the shop Tuesday.
Edit: yes the cruise was off.
Since this is my b*tching thread, I'd add a few other issues i'm working on. The wake plate doesn't work (lenco electric 5 lobe) and the wake plate gauge pegs with turning on the blower or trying to move the "blinker". I checked the connections at the blinker and they were secure; tried to check voltage but it's too tight of a squeeze. I'm hoping a ground is loose somewhere but quick poking around didn't reveal anything.
Also, the horn doesn't work and when pushing it there is clicking sound at the push in circuit breaker but the breaker isn't tripped (nothing pushed out) but with blower on the clicking noise goes away when pushing the horn button. Another weird thing present, when turning on the blower the nav light switch lights up and comes on. Please let this be an easy wiring issue!!!
New alternator fixed voltage gauge and check engine light! My ol man stated that voltage regulators rarely go out but guess that was the case.
Next thing, wake plate/gauge and dash issues.
Any idea what this potentiometer is for? Googgling it gives me little information. It's under the dash and has a nozzle that can be rotated back and forth, speedo calibration, wake plate? Attachment 25345
Guess it's for the speedometer. Nozzle must be to fine tune?
Yup, calibrates the speedo.
Sounds like a floating ground. When you turn on your blower, you provide a path to ground for the other circuits although not a very good ground going through a motor. Run a new ground wire or locate the bad connection either an open connection or a high resistance connection. You're getting there.
