Keep in mind, I believe he has the 3 post switch, and not the 4 post switch.
Look at it in this way. With a traditional 1/2/BOTH/OFF switch, you can dedicate one bank to the loads (engine, audio, lights, blower, shower, ballast, etc) while holding the other bank in reserve, fully charged, for re-firing the engine.
While the engine is running, there is no need to have the house or stereo bank, fully isolated from the engine battery. The downside is, the house bank gets no alternator charge, so it wont last long.
You can have a system made up of 2 cranking batteries, 2 dual-purpose batteries or a cranking and a deep-cycle. All work fine, just depends on how you use the banks and what the demands are.
Yes, I understand that. I guess I was just trying to adapt the philosophy of the 4 post switch with the limit of the 3 post switch. The 4 post only combines the stereo and engine when you want it too, so I decided to make the 3 post only combine when I wanted it too. Regardless, the OP needs to separate the positives of the two batteries.
I was trying to leave the ACR out of the equation. Didn't want to add anymore to the OP's original question.
I understand, but the ACR has to be part of the discussion if the 4 post switch is compared to the 3 post. The dual circuit plus switch does not work without an ACR or VSR.
MLA strikes again . . . . ACR/VSR and do not look back.
http://www.themalibucrew.com/index.p...switch-basics/
