		I have a 2007 supra that I upgraded.
This is what the sprinkler valve system looked like when I took it out and sold it.
https://c1.staticflickr.com/8/7327/8...21837a49_c.jpg
		Also had the same pump.  So long to that slow fill time. . . .
https://c1.staticflickr.com/6/5453/8...b52ab9db_c.jpg
		The little black switch opens/closes the valve.  Make sure those are not broken.
They cost around $25 each for the whole valve.
https://c1.staticflickr.com/6/5458/8...3108908e_c.jpg
		Also, to drain the bags, you need 3 other pumps to get the water out.  These were from a Supra, but I think Moomba used the same.
https://c1.staticflickr.com/9/8407/8...13f80d95_c.jpg
		I have identified all 3 pump out pumps. Your picks of the valves is exactly what mine should look like. I still cannot figure out why mine only has the one valve with the other two ports completely open.  I will soon look at getting the valves for mine. I will likely just try and get mine operational this year. I still have to buy bags as well.
		MJKSupra, where can I find those valves with the plugs already on them?
		You won't find them with the plugs on them. Those are put on by SC. The valves you can buy from Lowes or Home Depot.
		Craig,
Not sure what your time frame is but I am thinking about going to the wakemakers kit.  If so I will have my GIII stuff available.  Will know in about 30 days.
		Let me know JHutch.  This will be the last item on my list of may things to do.
		If you can buy from JHUtch, buy all the parts. Then you will spares. That is what someone did when they purchased mine.  Any of those parts (used) are hard to find.
Otherwise, you can get the valve from Lowes/HomeDepot.
Or buy both parts from a dealer - valve and solenoid.  Pay more.
